how to wire kicker COMP an CVR. 10'' to rockford fosgate 500.2
hondaracer48
i have an old *** rockford fosgate t500.2 an was using 2 kicker comps but just bought a CVR an need to know how to wire this. my amp is bridgeable. the kicker comp has 2 terminals, im not sure what ohm load it is. the CVR is a dual 2 ohm with 4 terminals. can i run one short speaker wire from one positive to neg. terminal an then bridge the other 2 terminals, then for the COMP just hook the speaker wires into the two middle speaker plug ins on the amp? yes i am going to buy another cvr in a few weeks just didnt have money for 2 right now. please help me with this! let me know if you need more info
im obviously a beginner at all of this. should i just disconnect the comp speaker an run the dual 2 cvr? if so how do i wire it
bridged at 4ohms and yes just the one for now, do it right or don't do it at all.
---------- Post added at 10:31 PM ---------- Previous post was at 10:30 PM ----------
check that link. What amp are you running?
he said the rf 500.2 so I would only go 2ohms per channel or 4ohms total bridged.
missed that. Run each voice coil of its own ch! JKJK don't do that but wire to 4 ohms bridged on the amp
•75 watts RMS x 2 at 4 ohms
•150 watts RMS x 2 at 2 ohms (250 watts RMS x 2 at 1 ohm)
•300 watts RMS x 1 in bridged mode (at 4 ohms)
•500 watts RMS x 1 in bridged mode (at 2 ohms)
•1-ohm stable (2-ohm stable in bridged mode)
i found this info about my amp. so whats the best way to run it an how should i wire this? thank you guys for the info, im trying to learn all of this on my own
•75 watts RMS x 2 at 4 ohms•150 watts RMS x 2 at 2 ohms (250 watts RMS x 2 at 1 ohm)
option 3 bud! one ohm bridged would be 0.5ohm per channel and that's your only other option.
Well it says my amp is 1 ohm stable. An thanks a lot I get it now lol
It is only one ohm stable on each channel. NOT bridged.
So don't wire the d2 sub parallel on that thing bridged. Use a d4 parallel on it bridged for the most power.
Your amp is 1 ohm stable per channel, but only 2 ohms when bridged. If you wired that sub to 1 ohm, you could only run it on one channel.
Since you can only wire your sub to 1 ohm or 4 ohm, you'd have to run it at 4 ohms bridged to get the most power out of it
Honestly you're better off just running your two kicker comps at 2 ohms bridged than that 1 cvr at 4 ohms bridged.
This, the SVC subs on that low amount of power are going to be more efficient than the DVC CompVR would be. Trade the CVR for a Comp+cash.
Trust me, we've ran 4 12" Comps on 1500w, then did a direct swap for CVRs and lost quite a bit of output (although did gain on the low end)
hondaracer48
hondaracer48
texas
hondaracer48
