Amp or Subs poured smoke!
I drive a 2008 Hyundai Tiburon GT Limited. I have gone through 3 different Amps in less than a year. In my car I have a Planet Audio 3000 watt mono channel class D Amp, three 10" Power Acoustic Subwoofers Dual voice coil (RMS for 1 speaker is 700 watts with peak power of 1600 watts), a 0ga power wire and ground wire, the paint on my frame was grinded down to the metal for the ground, and a Power Acoustic Single Din DVD/MP3/SD/USB headunit.
Well driving down the road the other day, I had the system going the backseat down and the windows down. I heard this crack like something just popped and started smelling smoke. By the time I knew it my whole car was smoked out. I stopped on the side of the road and popped the hatch and my 3 10"s were just pumping up and down every slowly. Also the Amp light was still on like nothing was wrong but it kept smoking. I have the subwoofers set up to run at only 2 Ohms. I don't understand what is happening. This will make my 3rd amp that is blown.
Can anyone give me some insight on why I keep blowing these things???
Well, you obviously need to rip everything out and see where the majic smoke icame from........next time, buy something better and quit maxing out your stereo
Well' date=' you obviously need to rip everything out and see where the majic smoke icame from........next time, buy something better and quit maxing out your stereo[/quote']
ya know, you'd be a lot more helpful if you didn't jump to conclusions like that.
lol if something in my car poured smoke, id rip it out and see what happened..........from the amp.....could be voltage drops, overheating, or just a simple FET, either way he needs new equipment. to the op, sorry to sound harsh it just that its happened to you twice before and it happens a third......it dont sound like an equipment problem
You still don't get two ohms.
4+4=8
1/((1/8)+(1/8)+(1/8))=2.66666667...ish
I'm assuming your amp is the AC3000.1D which is stable to 1ohm (it claims) so you could wire it a little lower.
Make sure your amp has plenty of airspace to cool off.
Make sure your speaker wire to the subs is big enough.
Those are all the suggestions I have //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif let us know what it was that blew the smoke and we can help a little more.
You still don't get two ohms.4+4=8
No.......
u take 2 8 ohm loads and wire them parallell you get 4. you take a third 8 ohm load and wire it parallell to the others.......you get 2 ohms
You never really wanna do this.
Umm pretty sure this is correct
If its the subs that were smoking its because you didnt tune your amp correctly and the subs saw a very nice clipped signal that put them on the edge of catching fire. If it was the amp I bet money on voltage drop popped some internals and caused some magic smoke.
Southeast Rage
Southeast Rage
Orangeburg
Haunz
