Amp Opinions Needed
  • 6
I got two Soundqubed HDS3 15s and they're on a Kicker ZX1500.1.. I want to push more power to them.. They're 1200 watts a piece and I want to push that amount.. The twist in the situation is that they are 2 ohm speakers because I bought them to be compatible with the Kicker amp, so I will need an amp that will push out 2400 watts @ 2ohms.. The only thing I could come up with was the Kicker KX2400.. Any suggestions?
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
134
330
461
  • Locked
748
Ike_Turner
Ike_Turner
Hattiesburg, MS
Jeffdachef
