Amp on but no output from sub.
M5AM
I have a Diamond D9 and two D6 amps. My front channel works but I get a hissing from the speakers slightly when the ignition is on and more when the car is started. I grounded each amp with stinger HPM ground feet and 4 gau wire.
Now the other problem is my sub is not working, the power light is on on the amp but there is no output at all. I checked the deck(Eclipse 8454) and the non fader/low output is at 10.... I triple checked the RCAs and the only other problem I can think of would be either with my terminal cub on the back of the box or something inside the box happened.... I am planning on taking it to the shop tomorrow but would like to know if there is some common issue that I am over looking... thanks.
Old post but just thought I would say that it was the RCa out puts from the amp not putting anything out, so I sent it back to diamond and should have it back in about a week.
M5AM
M5AM
Portland, OR
M5AM
