amp not working
RJones87
I recently installed a Hifonics hifi1000.1d. The amp turns on, but it wont send anything to my subs. Im assuming there is suppose to be some type of voltage coming from the speaker terminal, but they read and 0v.
Should I return the amp or is there something I can try.
Seems to be a common issue with Maxxsonic's Monoblocks, I ran into this 3-4 MB Quart DISCUS 1500.1d's and a couple of the Brutus amps that shared the same board.
I would take it back imo.
dmm put the leads on the rcas ground and power and see if you get a reading . dont plug them in .this is why i dont buy or sell maxxsonics amps .have had the issue in the past with they're amps .
You can substitute another input signal to eliminate the HU and RCA cables. Plug an iPod or MP3 player or even a portable radio into the amp's inputs instead of RCAs. You'll need an adapter to go from the headphone to dual RCA plugs.
RJones87
RJones87
United States
maylar
