Finally got to hook up my new subs and what not today, and the amp wont take power. I tested volts all the way down to power cable, and it was steady the whole way. Once the cable is plugged in the amp, it stops reading any voltage at all. The ground and remote wires are fine, even tried the remote to the power. RCAs are tight, subs werent plugged in.
Its a Planet Audio P2250D. The fuse is a 300 amp Kicker, and using all 1/0awg kicker wire. Fuze is in tight, and there is 14v+ before and after it.
Any ideas? Maybe the terminal on the amp came loose on the inside?
