Amp No output after blown fuse
Mechorganic
Equipment:
I have a boston acoustics gta 1000m and a morel ultimo sc 10" 2 ohm. Knukonceptz 4awg wire from the battery with an in-line 150A ANL fuse, 4awg ground.
Situation:
Hooked it all up, but the Knukonceptz kit I purchased came with a 80A AGU fuse which blew after 2 minutes of playing so I went to my local audio shop and purchased a 150A ANL fuse and hooked it all up together. I turned all the knobs down and it played for a few minutes and cut out again, but this time I checked all the fuses and they are all intact. The power led was blue for the first half hour of me fiddling with knobs. Took it all apart and rewired everything and when I turned it on again the power led was red, which indicates some sort of power protection mode with all the gains turned down.
Im not trying to win any comps, just for a little bump. Any help to get my system going would be appreciated.
Grab a digital multimeter from walmart (like $5) and start checking your voltages. (at the amp terminals, fuse terminals, etc) That's where I would start, make sure you have 12V (or 14V with the vehicle running) at the amp and on the remote terminal. Also try disconnecting the speaker output leads (going to the sub) and powering up the amp.
The more information you give us the easier it will be for us to help you.
Ok, going to grab the multimeter in the morning and get readings, thanks for letting me know where to start
So my multimeter is reading between 30 and 31 at the amp terminals and the remote terminal is between 26 and 27 when the car is running
This is the multimeter I have, those initial measurements I took were with the Voltage ~ 200 @ about 1 oclock on the dial. Whenever I try to take measurements in DCV any settings or the DC10A it creates a short in my system and sparks fly from the terminal. Not sure if Im doing anything wrong though, but pretty certain thats not supposed to happen.
...what did you have it set on? Should be on DC Volts and it should be around 12-14V
Thank you very much.
The readout from the battery to the terminal is 14.06V and the remote is 12.95V
on your dmm. put the red lead/plug in the other hole.
put your selector switch on the dmm to DCV - 20
Those are good then, I would suggest disconnecting the sub(s) and powering up the amp. Report back with the results. If it powers up fine then I would do like jokers10 suggested and check the resistance of the sub to make sure you're not presenting too low of a load to the amp.
http://img832.imageshack.us/img832/1476/file18051.mp4
Here is a video of my DMM while running, all my knobs are turned all the way to the left which i believe sets everything to the minimum. Pretty steady @ .1
lol, ok you misunderstood. You need to leave the sub in the box and measure what the resistance is of the sub itself...we were just trying to make sure you didn't wire it to a low impedance load unintentionally. But now that I look it seems your sub is a single voice coil sub meaning that would be impossible...(so forget that)
When you powered up the amp with the sub removed did it go into protect at all like before?
Oh sorry, yea it is a single voice coil sub. No it did not, the light stayed blue the entire time.
Mechorganic
Mechorganic
Miami
Mechorganic
michigan born
    May 14, 2026
michigan born
    May 14, 2026
