Amp needed 18" TC Sounds LMS-5400
I was hoping to send a little more power to this sub than those have to offer. I do like Arc/zapco. What else is out there that has 2000-3000 watts that has low distortion, high dampening factor, & a high S/N ratio? Come on guys!
I would love to see you pick the amplifier I hooked up to your sub and send it 2500rms by ear. You might feel better by spending more money- however you will not hear a difference.
Kicker 2500.1
I have owned a few amps. I have been able to hear a difference from one amp to another. I have heard amps with raw power but no speaker control. I want something that can throw a ton of power and sound good doing it. I'm sure Kicker puts out the power but I'm not so sure that I couldn't pick it out up against some of the more high end amps. I have went the cheap route and I've went the expensive route. I prefer to spend a little more and get something that I know will sound great, & last for a long time.
How about the audiopipe AP30001D...its 3000rms @1ohm...i believe your speaker is a dual 2 ohm and 2500watts rms...so this may be slightly overpower....but it's a great amp for the money...its $397
http://www.rickiesdiscountelectronics.com/audiopipe-ap30001d-audio-pipe-3000-watt-class-d-amp-20820.html
You might also want to try this us amps MD-3D 2000W RMS Merlin
its 2000 watts rms@ 1ohm...its $489
http://www.rickiesdiscountelectronics.com/us-amps-md-3d-2000w-rms-merlin-2-series-mono-block-subwoofer-amp-16493.html
Here is another us amps that is AX-3200DE 3000W RMS Mono Block
3000rms @ 1 ohm...may be really out of your price range...$1299
http://www.rickiesdiscountelectronics.com/us-amps-ax-3200de-3000w-rms-mono-block-class-de-ax-series-amplif-16495.html
Here are some specs on the AX-3200DE
90% Efficiency at clipping
Master / slave Input Drive capable
Dual Power Toroids
Variable Low-Pass (LP) Crossover
Subsonic Filter
Non-computerized SAT
Remote Bass Gain Control Included
S/N >86 dB
Damping Factor >250
todj
Mr. Knowledge
todj
Reno, NV
Gavriley2007
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
