Amp myth question
Dont know who came up with that... but if your not using a channel, all you'll have on it is potential... no actual flow, so there's no real current to do any damage
I know some electronics don't like not having a load on them. The internals keep trying to make power but have no where to put it.
hifonics Goliath had a problem when you would gain match amps with no load they would go up in smoke.
happened to a friend of mine with a z1 he took out the sub and still had the amp remote hooked up so one day hes driving along and the amp went up in smoke.
so i say its a fact that with no load being on the amp (load being a speaker) they can go up in smoke.how many of them will do it I have no idea but i do know of 2.
how about the fact that the first sundown 1500's would burn up the slave amp if you used a certain brand RCA ?? true it happened to many people including my self
hifonics Goliath had a problem when you would gain match amps with no load they would go up in smoke.happened to a friend of mine with a z1 he took out the sub and still had the amp remote hooked up so one day hes driving along and the amp went up in smoke.
he actually made a thread about that on another forum about the FAQ. that just so happened to be one of them. yeah he was saying certain brand RCAs wouldnt work with the slave amp cause something how the terminal was or something.
setting your gains without a load can run into serious problems... but i've never seen an amp fry from just not having anything hooked up to it. all the cases that i've seen where that was what the person thought it was, it ended up being caused by something else
I have a class A amp at home and it run pretty **** HOT at idle and I think I read somewhere that actually playing the stereo loud will make the thing actually cooler because instead of dissipating the unused energy through the heatsinks, it will go to the speakers. It kind of makes sense if class A is basically running all out all the time even with no signal. This could all be a theory and unfounded of course. Someone probably just made it up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nope, but it won't hurt it just sitting there, either //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This isn't a myth at all for tube-based amps - the output transformers need to see a load or you'll be replacing them because of shorted windings.
accuab
accuab
Athens, AL
JimJ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
