Amp Line In Help!
Its only one sub, ch1-ch2 bridged to one voice coil, ch3-ch4 bridged to the other voice coil.
While the above-mentioned method is possible it is generally inadvisable unless you are very good with a DMM and are fairly certain you can gain-match those bridged channels to give the exact same signal to each voice coil. Otherwise you'll risk sending unequal inputs to the different coils which will eventually lead to VC failure.
Why are you using a 4ch amp to power a single sub?
I had 2 subs but i was tryin to get to more power so decide to hook up one, but it`s true i hear the sub is playing like 2 signals, but still if bridge 2 subs to the 4 ch, where i connect the 2 rca leads from the HU? becuase ch1-ch2 will be for 1 sub ch3-ch4 for sub 2, so igot to connect let's say red line to ch1 and white to ch3?
thanks
DoubleOB
4R05
DoubleOB
CA
DoubleOB
