amp kit. which amp kit is right?
Hi everybody, i have a pair of component speakers in the front, and a pair of mid woofers in my back dash as well as a sub. I have two amps and a total of 2500 watts. Total rms is around 700 watts. Which amp wiring kit should i need? which guage, and which brand? Also which capacitor should i get? what should it come with and do the capacitors usually come with all essential wiring stuff???
do you intend on upgrading later on? if not, a 4 gauge ofc run to a distro block will work just fine, then just ground each amp individually to the closest piece of thick sheet metal and sand down the paint
you'll need to run a 9 wire conductor from the headunit to wherever your mids/highs amp is to move your speaker wires to somewhere more useful. use the 9th conductor for your remote turn on wire
so.. ring terminals, 15-20ft of positive 4 gauge, 5ft of negative 4 gauge, fuses, 15-20ft of 9 wire conductor, and 2-6ch of RCAs depending on your headunit
edit: don't post multiple threads for the same question please.
I would get a 1/0 kit and any of the nicer brands will do
You could get by with 4awg but it's not much more for 1/0 and it will provide room for updates
Get any of the nicer brands like shok or you can go with regular welding cable
Thanks alot for the advice, i went with Rockford Fosgate RFK4D 4 Gauge Complete Dual Amplifier/Amp Installation Kit from ebay. It has everything i need to set up two amps. What bout the capacitor? I think i should get one so i dont dim the lights. Sorry for multiple threads XD
chevy_aveo_2005
northlake il
chevy_aveo_2005
vegang
vegang
