Amp Kit vs Separate Purchase
ninjawhiteboy12
I am debating on if I should buy two amp kits(one for my mono and one for my 4 channel) or if I should just buy a 50ft spool of 1/0 wire and a 33ft spool of 4 gauge and get the RCA's, fuse holders, and everything else separate. Which would be a better value?
the 1/0 roll is $90 and the 4 gauge is $30
I would be getting Knu amp kits
Thanks guys
I run all 1/0 and use a 4 guage reducer on my mid/high amp. No need to buy more than you need. I bought my knu wire on ebay and you can buy however much you want to the nearest foot.
so it would probably be better to get the spool of 1/0 and get a small amount of 4 gauge to use to attach to the 4 channel from the reducers and just buy all of the other stuff separate.....that is sounding pretty good to me
any ideas on where to get cheap fuses/fuse boxes, reducers, and RCA's?
If you use 1/0 to 4 gauge reducers you wont need any 4 gauge wire at all. The reducer allows you to run 1/0 to your mid/high amp which apparently accepts 4 guage minimum.
ninjawhiteboy12
ninjawhiteboy12
Northern California
Chrispy
BP1Fanatic
BP1Fanatic
