Amp is on but no sound question
  • 6
TupacThaDon1971
sandusky
had the system hooked up fine and then took out because was going to sell but decided to put back in. Anyways, the amplifier is the Alpine M-1000 or wahtever, it turns on but no sound all of a sudden...i'm thinking it may be my RCAs went bad or something, any other input???
Yeah I don't have another set as of now and it's a pain in the *** getting behind the CD player lol, why I was sorta hoping maybe I was missing something else....guess I'll have to try it and see
easy mode) get a cheap 3.5mm to rca adapter, and use you phone as input. that will easily tell if amp is ok if you get sound.
normal mode) play a sine wave on head unit and use dmm to verify a signal is being sent. Set dmm to ac, while checking existing rca.
I think I'll just try some new RCA's sometime....I'm quite lost on the phone ordeal lol....thanksS though
then try normal mode.. Do you have a Digital multimeter? Harbor freight sells them for $5. Everyone should have one imo. Testing the rca before replacing could save a bunch of time, and $$.
no i do not, but i'm positive there is one at work.....now say i have that in hand....i'm supposed to ''play a sine wave" (lost on that), as the rest of the steps in order to tell
That ish don’t work with the new iPhones
Not sure how playing a sine wave is gonna help in this situation.
Cmon bro, your smarter than that.
So what would I do with the Dmm once I have it regarding the rcas
Easy. playing a sine wave is just an easy way to test signal, as its a constant. You can play music too, but the dmm will jump all around with the bass.
To use a dmm on the rca, simply set meter to AC voltage. then, unplug an rca coming from head unit at the amplifier. Press one probe on dmm to center pin of rca, and other probe to the outer "skirt" of rca. you should read somewhere around 2-6v AC. if not, apply same test at head unit terminals to rule out a faulty rca, or head unit not sending signal.
Maybe...but I would start with the simplest things 1st and in case OP doesn't have any test tones/sine wave tones on tap.
Update. Took line out back and just upgraded my head unit. Now my sound only plays when fade is in rear and balance to left. Ugh. One thing after...
20
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake...
10
114
  • Locked
287
TupacThaDon1971
TupacThaDon1971
sandusky
TupacThaDon1971
    May 16, 2024
    May 16, 2024
