amp installation
  • 3
burto78
I have a 200watt pioneer hooked up to 2-10" roadmaster subwoofers, a 400watt jensen hooked up to 2-10" jensen subwoofers. I am about to add a 600watt jensen to 2-12" mtx roadthunder subwoofers. I was wondering If I will have to get a bigger alternater, or if a bigger battery will push it or what what I can do to make all this work?
Thank You
Burto78
If your headlights dim in sync with the bass. Then a 1 farad cap will help. Get rid of the roadmasters. Use the pioneer amp for your front speakers.
actually .5 a farad would prolly do if dimming occurs, since that system isn't really TOO power hungry. i doubt jensen, and road gear, and MTX RoadThunder subs (10" if that) will drain a hell of a lot of power @ one time
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
8
Best route is to start with a DSP. It will level and boost the signal with the option of having an amp remote trigger. For this you can tap before...
burto78
burto78
bluefield, va
more_spl
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
