Amp installation problem.
Daniel
Caraudio.com
863
SFLA
I am going to install my system for the first time by myself soon, and i have two blaupunkt pcwi1200, 12" subs and one jbl 600.1. i was wondering if i needed certain fuses, or a farad cap, and i was also wondering what gauge wire i need from the amp to the battery and what gauge wire i need from subs to amp. do i need a distribution block or anything like that?
thanks
If your only running one small amp, you should be fine without a farad cap.
For what size wire, you could go with 8 gauge or 4 gauge.
8-This is what size your amp wants connected to it...its all you really need. However, if you upgrade in the futur you might need bigger wire such as...
4-If you get this size, then you will need a distribution block. This is becasue your amp cant take that big of a wire. However, this leaves you open for exspantion in the futur. All youd have to do is run a very short wire from the block to the new amp instead of running new wire from your battery. 4ga is also a little more exspsensive.
As for fuses...I have a 60 amp fuse on my 4 gauge wire...I havnt blow a fuse yet so I quess it works
Hope that helps.
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
8
Best route is to start with a DSP. It will level and boost the signal with the option of having an amp remote trigger. For this you can tap before...
Daniel
Caraudio.com
Daniel
SFLA
longstreet
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
