Amp installation problem.
Daniel
Caraudio.com
863
SFLA
I am going to install my system for the first time by myself soon, and i have two blaupunkt pcwi1200, 12" subs and one jbl 600.1. i was wondering if i needed certain fuses, or a farad cap, and i was also wondering what gauge wire i need from the amp to the battery and what gauge wire i need from subs to amp. do i need a distribution block or anything like that?
thanks
If your only running one small amp, you should be fine without a farad cap.
For what size wire, you could go with 8 gauge or 4 gauge.
8-This is what size your amp wants connected to it...its all you really need. However, if you upgrade in the futur you might need bigger wire such as...
4-If you get this size, then you will need a distribution block. This is becasue your amp cant take that big of a wire. However, this leaves you open for exspantion in the futur. All youd have to do is run a very short wire from the block to the new amp instead of running new wire from your battery. 4ga is also a little more exspsensive.
As for fuses...I have a 60 amp fuse on my 4 gauge wire...I havnt blow a fuse yet so I quess it works
Hope that helps.
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
Best route is to start with a DSP. It will level and boost the signal with the option of having an amp remote trigger. For this you can tap before...
173
  • Locked
413
Daniel
Caraudio.com
Daniel
SFLA
longstreet
    May 20, 2024
    May 20, 2024
