Amp installation (blowing fuses)
BulldogSr04
I am in the process of installing a new kicker 300.4 and I have everything wired to my speakers and I hooked up my power and my ground and at first i didnt have any power. So I changed the ground and mounted it better then I changed the adapter for the battery. When i touched the adapter to the battery it blew both of the fuses. So i d/c the power to the amp and put new fuses in and hooked up the adapter to the battery. Well i put it back in the slot to hook it up and blew both of the new fuses. What should I do to finish hooking it up and save me from buying new fuses or blowing the amp.
thanks
Check your speaker wires for a short circuit. And make sure the power and ground wires are connected to the right terminals and not touching each other. If thats not it, than there is a short inside the amp and it will need to be repaired. Using a larger fuse than recommended by kicker may void the warranty and ruin the amp.
Originally posted by indosia Check your speaker wires for a short circuit. And make sure the power and ground wires are connected to the right terminals and not touching each other. If thats not it, than there is a short inside the amp and it will need to be repaired. Using a larger fuse than recommended by kicker may void the warranty and ruin the amp.
I agree
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
Best route is to start with a DSP. It will level and boost the signal with the option of having an amp remote trigger. For this you can tap before...
154
  • Locked
369
BulldogSr04
BulldogSr04
Jennings, LA or Baton Rouge, LA
chris229
audiobaun
    May 19, 2024
    May 19, 2024
