Amp Install
PEPPER061781
situation: i bought a small amp to adapt my head unit to my car and to give alittle juice to the speakers...it is a four channel amp...my speakers need a 4 omh charge...so the amp puts out 4 ohms...but the reccomended hook up is parellel..
Whats the solution? any help would be great.
If your speakers have 4ohm svc then run one channel to each speaker. Assuming you only have 4 speakers. So your Front channels on your amp run your front speakers and the rear channels on your amp run your rear speakers. Pretty straight forward. Your amp will see a 4ohm load. If you only have two speakers see above post. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
PEPPER061781
PEPPER061781
ILLINOIS
PEPPER061781
michigan born
    May 14, 2026
michigan born
    May 14, 2026
