Amp install questions
ausman
Iowa
I have a 250 rms watt Rockford Fosgate amp and a 1000 rms watt Rockford Fosgate amp that I'm putting in my 2001 v6 mustang, I am wondering what i need to do as far as what gauge of power and ground wire to run and do i need a HO alternator or a better battery to run this system properly?
Thanks
You'll want a good battery. Deka Intimidator. Oversized from stock size if you can fit it. The bigger the better. Group 31 if you can.
You may or may not need a new alternator. If you want to really push those amps to the limit, you probably will. A good - and bigger - battery may or may not be enough. You can do a second battery if you want, keeping the stock one under the hood and a bigger one in the back.
If you do a second battery/battery location, you want to use a minimum of 0 AWG wire. If you don't, 4 gauge will work. If you want to be able to upgrade amps to even more power later and/or a battery in the back later, use the 0 gauge now. Personally I say big battery under the hood and alt if necessary.
I know you won't have much space back there but I'm not ever sure I've really checked a New Edge out up close all that much.
what dragonrage says stay with 0 ga. and just get 0/4 ga distribution block to run 4 ga. from there to the amps and also the big 3 under the hood too
Ok so i already have 4 gauge ran, so 4 gauge will work without big performance loss if i dont plan on upgrading later.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
926
ausman
ausman
Iowa
Tenacious
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
