Amp install - 2007 Saturn Vue
bobl61
I have a Valor VPA1005 Amp that I'm installing in a 2007 Saturn Vue. I'd like to hook it up to my 4 speakers (I've replaced the stock speakers with Kickers in the rear and Blaupunkts up front). I'm hooking it up to the factory head unit and a bandpass sub (2 x 10" subs). I need some advice on where to feed the wire through the firewall for the power and any tips on running the new speaker wire to the in-door speakers.
I installed an amp in my Beretta, but there was easy access for the firewall pass through and the speakers were in the rear deck. Appreciate any help //content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
If there are no holes in your firewall already, either drill new ones or run power wire under the car. Drilling is the better choice, but make sure you know what is on the other side when you start to drill.
bobl61
bobl61
Blackwood, NJ
tjjohnson91
