amp help
WTF is a CV 15? Do you mean Kicker CVR 15"? If so, you're going to get another dual 2 ohm and your final amp load will be 2 ohm (or 0.5 ohm) but I wouldn't do that daily). So the amps you're going to be looking at should do around 1000 rms @ 2 ohms. If what I'm assuming is correct.....
Ok would that 1 1000w amp @ 2 ohm be enough for two of my subs to run at 500 rms each? Or is it 1 amp per sub? Also what brands are true 1000w?
Found a kenwood kac 9105d 900w rms@ 2 ohm for 175 on sale..would that be a good choice? And I'm confused..if my sub is 500 rms y get amp with higher rms?
Discus series discontinued..onx looks like new series..those good? About same price as hifonics kenwood..is kicker best or just paying for name?
gpimpin
gpimpin
Winston
LosIsATool
