Amp Help?
pimpingmyride
So I just two two Infinity Reference 1060W's and a box for my 1999 Honda Passport that my friend didn't need any more. I was wondering what type of amp I should buy to make them sound good. Any amp suggestions?
Here are the specs on the subs:
Subwoofer Size 10"
Subwoofer Design Round / Circle
Main Cone Color Silver
Voice Coil(s) Single (1 voice coil)
Impedance (per voice coil) 4 ohms
Peak Power Handling 1100 watts
RMS Power Handling 275 watts
Woofer Composition Polypropylene
Woofer Surround Rubber
Minimum Sealed Box Volume 0.75 cubic feet
Maximum Sealed Box Volume 0.75 cubic feet
Minimum Ported Box Volume 1.75 cubic feet
Maximum Ported Box Volume 1.75 cubic feet
Sensitivity 91 dB
Frequency Response 25 - 400 Hz
Xmax (millimeters) 13 mm
Top Mount Depth 5-7/8"
Shallow Mount Installation No
Cutout Diameter 9-1/4"
Recommended Enclosure Type Ported / Vented
Sealed
Subwoofer Grille No
Re-Cone Kit Available No
If they are SVC 4 ohm's and you have 2 of them, then ~600rms @ 2 ohms is what you will want to get them their rated power. It is always good to have some headroom though.
You can either get a 600x1 @ 2ohm or a 4 channel that bridges down to 300x2 @ 4 ohm
A million amps fit this description so you are in luck //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Whats the difference between the 600x1 @ 2ohm and 4 channel that bridges down to 300x2 @ 4 ohm?
In most cases the 600x1@2 ohm will be a Class D Mono, so usually more efficient (less current draw)
The 300x2 @4 ohm will usually be Class A/B and less efficient.
If you have the option to go 600x1 @ 2 ohm, i would. It'd give each sub 300rms.
Just giving out more options by mentioning the 4 channel route:)
pimpingmyride
pimpingmyride
Marietta, GA
Bumpin' Goalie
vegang
vegang
