Amp help please
Justinschmidt1
I have a kicker amp...not even sure of the model number right now..its like 6 channel ,,,its powering 4 alpine speakers and 2 subs but the problem is only 1 sub is getting power...could It be the amp is bad or should I check wiring?...the red rca plug works for both outlets left and right but the white one wont work for either......
swap the sub that works to the other sub out put. see if it works.
also if you have a multi meeter. you can check the voltage on the rca cables. sub outputs. etc. that should let you know if your getting somthing.
I can get both the left and right subs to work when switching the rca cables ..so its gotta be the one rca cable becuase im getting power to both subs....ill try switching the rca cables on the back of the head unit and see what happens
Justinschmidt1
Justinschmidt1
East Coast
Justinschmidt1
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
