amp going in protect mode
putting all the setting on the amp to 0 didnt bring it to 22 volts with the level all the way up, so i turned all the setting (sub sonic, bass boost) all the way up, the adjusted the level. Correct?
Can you follow directions at all????Its very simple. Follow the chart makeshiftaudio provided and you should be good. I need to do the same with my amps once I get them hooked up.
dude i did follow directions!!!!! and the directions said turn down all the setting and change the gain... but guess the **** what. with all the settings on the amp down, and the level up, the amp didnt even hit 20 fukin volts, so i turned all the settings up and went from there
sorry guys, im an idiot and you all win. Had my neighbor come over to help with the dmm and all is perfect now. Amp runs well and reads the corect voltage.
Didn't have it set to AC? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Happy all is now well...crank that bass and go vibrate some earth! //content.invisioncic.com/y282845/emoticons/2thumbs.gif.fdc3ba010dbb42b61704534b46d02fe4.gif
fastfive09
fastfive09
SLidell, LA
fastfive09
