amp goes into protective mode
So my Sony XM-ZZR3301 amp will go into protective mode as soon i turn volume up. The system was previous working with no issues. I checked the fuses in the amp and neither is blown. Anyone have any ideas? I do have the subs dropped down ohms if that matters?
Low ohm load is ur problem
Xplod XS-GTX120LS Woofer X 2
Impedance 4 Ohm
Driver Type 12" Polypropylene Woofer
Minimum Frequency Response 42 Hz
RMS Output Power 300 W
PMPO Output Power 1000 W
Amp is
ZR Series Class D Monoblock Amplifier
RMS Power Rating:
4 ohms: 330 watts x 1 chan.
2 ohms: 600 watts x 1 chan.
Max power output: 1100 watts
It was working and all sudden stopped.. I pulled the speaker wire to one of the subs and the amp still did the same thing
MrFordRanger
MrFordRanger
NorthEast Ohio
MrFordRanger
vegang
vegang
