Amp Goes Into Protect, But Only In The Morning
What amp?
And what voltage does your alt charge?
Alts will over-charge when cold....so, your amp may be getting higher than 15v and jumping into protection.
Unlikely...but possible.
its not significant difference in temp...like today when i left for work it was about 70 and the high was low 80's....i dont think tahst too drastic is it?
amp is a Cadence TXA-6004....i dunno what my alt charges at but its a 200 amp alt from mean green
no my amp is not in the spare tire well....i have a 1998 jeep grand cherokee....its installed in the cargo area
it hasnt always done this either...jus started in the last couple weeks
Check your charge voltage one morning. I bet its alot higher than usual.
For example, my alt charges at 14.6-.8v when cold...13.8-14.2v when warm.
Your alt may be charging at 15.5+ when cool and shutting the amp off.
i dont what it charges at exactly but i know it doesnt get up THAT high....i know it isnt perfectly accurate but the meter on my 880prs shows it charging between 13.1 and 13.4 when warm and from 13.6-14.1 when cold
it happened again today...jus went out to check if it was working again n it is....also, i installed my 20.1 and rl-p last night and the 20.1 stays on and runs just fine but the cadence has its little mood swing....this boggles my mind //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
walkychalky
walkychalky
San Jose, CA
luvinthebass
