Amp Gain Setting - Subwoofer
tracyrick
Limited035
I can't find a conclusive answer on this:
If my Alpine HU has a Sub volume control, do I turn that up to 15 (max) before I do the gain setting test, or turn it down to 0 ?
Just did the 50hz test tone on my JL 500/1 amp (for a 12w6 at 2ohms) using an AC multimeter. Got to 31.6V with the gain turned up only 25%. Sub sounds weak - I think.
Turn the sub volume control to max when setting the gain. Otherwise the control is useless.
As far as the sub sounding weak, use a -3dB or -6dB tone to set the gain. That will better approximate the signal you get from music and give you more output but still be reasonably assured that it won't clip.
tracyrick
Limited035
tracyrick
Longmont, Colorado
406er
Mike Mccabe
