Correct. u will not need to be anywhere near thatAnd increasing means closer to 0.2v?
Every amp will be different its hard to tell but if u dont have a dmm id set it to normal and go from thereWhere would 2v output be on gain dial?
Yea and thats 400w max its really only about 180rmsOk thanks. It doesn't bounce much at 70% volume on head unit is that because it only 400 amp?
Yes 80 is correct and u want it at +6 specs i saw said it did 185rmsx1 @4ohmsThe closest thing to sub level is subwoofer control and it had a hz rating I set it to 80hz as the amps lpf is on 80hz and that is locked to 80hz. Then it has -24 up to +6 and that was on 0 default now it hits a bit harder on +6 and another number which is only -6 or -12?
