Amp for Orion system?
  • 2
Hi all,
Fairly new to the car audio scene, so, after many hours of fruitless research into possible solutions, I have decided on the 'direct question method'.
So, here's the deal. I'm an extreme basshead, and I have chosen to kit out my 1979 Honda Civic with a single Orion HCCA 15.2 subwoofer. (I have extensively researched this sub and understand its power-hungriness etc.). Also, to follow suit with the Orion brand, I have decided to go with two Orion HCCA88N midrange drivers and two Orion TN-1 Bullet tweeters. Now, seeing as I'm about as technically minded as a tree, I need help with literally every other part of my system. (Head unit, wiring gauges, capacator or not, amplifiers, anything else...) My main question is what amp do I need for my sub (thinking monoblock single channel) and which for the mids and tweeters (decided on separate amps). Any general advice is GREATLY appreciated. Thanks in advance,
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
243
452
Bassaddic
Bassaddic
Norfolk Island, Aus
Bassaddic
Decebal
    Jun 10, 2024
