Amp for JL W7 Wedge System
Tomcool
I have a JL Audio W7 12" Wedge System and I need to get an amp for it. The specs on it are as follows:
HO112R-W7
Driver(s): One 12W7-3
Continuous Power Handling: 750W
Final Impedance: 3 ohm mono
Enclosure Type: Chamber-coupled, slot-ported, rear-firing design
Finish: Dark gray carpet with red insert
Net Weight: 119.0 lbs. / 53.95 kg
Dimensions: (H) Height x (W) Width x (D) Depth 17.00 in. x 34.00 in. x 20.50 in.
432 mm x 864 mm x 521 mm
I was thinking of a JL 500/1 or a Alpine MRP-M850.
What do you guys suggest, my budget is around $300
not sure what to recommend seeing how your price tags are very much different then the ones i have here:mad://content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif:mad://content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif:mad://content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif:mad: but i wanna add that this sub prefers good control over power...id go with 500/1 out of those two...havent heard it tho, but from some tests i read a while back its a pretty decent amp and will put out those 500w and add some..
Thanks for the reply, I think I am going to go with the 500/1 althought a few ppl have told me I should maybe go with the JL 1000/1....it costs a good amount more, do you think there will be a huge difference?
HO112R-W7
i love noobs like this.... dude didnt leave a **** thing out on that sub and box...but the color of the sub.. ahha
I copy and pasted it from the JL Site, did not bother to take the extra time to remove the color...
did I mention you can **** a dick?
Tomcool
Tomcool
Orlando, FL
Tomcool
