amp for edk
bshime45
WI
i want to go with a ported box in order for the sub to get a little louder.. i'll be getting the new flat cone edk.... i've read that you need a subsonic filter on the amplifier if you use a ported enclosure.... i was lookin at a profile amp to power it, but it doesn't have a subsonic filter.... ive searched in this section and i haven't got an answer... i want an amp that would power the edk, prolly around 400 watts, but which also has a subsonic filter.... unless i don't need one at all... any comments are appreciated.
i'm hopin not to spend too much, i'm gettin the dual 4 and wiring it down to 2 ohms i believe....
As long as you keep your enclosure tuning freq low(25-33Hz)
You won't need a sub-sonic filter with 400w of power.
If you tune higher for SPL and increase power the need for a sub-sonic filter increases.
so i'm not really smart with the tuning... if it's just for daily driving what should i have the box tuned to
202
406
491
  • Locked
783
Amp
567
bshime45
bshime45
WI
BIGGUP21
