Amp for Cvr's
i think u can find the brutus 1610 or whatever the exact model is for under that, the aq 1200 for prolly 200...or maybe a lanzar or directed for around 150, they should do rated
thanks i found a Lanzar 2 Channel 1200-W for $100
look either on the box of the back of the sub, should say wheter they are dual 2 ohm or dual 4 ohm all cvrs are dual voice coil. if its dual 2 ohm you ned an amp that does power at 2 ohms if its dual 4 youll need an amp that does power at 1 ohm.
for subs most peopple run them off of a mono amp, thats 1 channel, they are more effecient and when you wire the subs correctly thats all you need you should read up some more about sub wiring before attempting this, or have someone who knows what they are doing to help you.
yea i dont know how to wire this up but two of my friends do they build boxes and set up systems so im probably gonna let them do it
I wouldnt get a Lanzar. I would go for a little higher quality amp so you can keep it longer. The suggestion for the AQ1200 is good, or there is someone selling an Orion 1200 watt amp on here for like 160 plus shipping. That would be great too. Or just get a Hifonics BXI1206D off EBay for 170 shipped.
i got someone sellin e a hifonics brutus 1206 for 150
Also i need some ideas on my box. should i build or buy. i want it ported so i was jw what i should do got any links pm me with them or if u know anybody on ca.com tell me and ill hit them up
get a box built,, to the specs or so,,, is ur subs dual 4 ohms, or dual 2 ohms??? dont buy a cheap amp....... get a hifonics like said, or even better a audioque 1200d
Ruthless1992
Ruthless1992
Wf
mccanng
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
