Amp for Cvr's
id prolly put like a 1000 watt to 1200 watt amp on em, geta nice box and set ur gains right u can prolly get some good bass out of em....lol i alway reccomend the aq 1200d but i think it would be great amp for the subs
my jbl gto1201.1II would be great for them //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yea thats looks pretty good i just need something that doesnt cost over 200 because i dont really get alot of money
this has 2 channels right because on that site it says 1
it has one channel, which is gonna be better then ur two channel anyways, at least more likely depending on the amp...but dual 2,4? im assuming the subs are dual 4 each so would give u either 4 ohms hooked up a pair or 1 ohm, id try about 1200 watts to em ina good box at 1 ohm...that jbl would prolly do nice especially if that guy has his saz1500 running on the same pair
i think u can find the brutus 1610 or whatever the exact model is for under that, the aq 1200 for prolly 200...or maybe a lanzar or directed for around 150, they should do rated
yea thats exactly what i was thinking
They have dual voice coil config
look either on the box of the back of the sub, should say wheter they are dual 2 ohm or dual 4 ohm all cvrs are dual voice coil. if its dual 2 ohm you ned an amp that does power at 2 ohms if its dual 4 youll need an amp that does power at 1 ohm.
for subs most peopple run them off of a mono amp, thats 1 channel, they are more effecient and when you wire the subs correctly thats all you need you should read up some more about sub wiring before attempting this, or have someone who knows what they are doing to help you.
85
  • Locked
263
Amp
284
350
Ruthless1992
Ruthless1992
Wf
mccanng
    May 16, 2024
    May 16, 2024
