Amp for BTL 12?
FeS RoY
getting a Dual 2 ohm BTL 12, should i get a
Alphasonik 1000DA
1-Channel Class D Monoblock Power Amplifier
RMS Power Rating: 2060W x 1 chan. at 1 Ohm Mono
RMS Power Rating: 1500W x 1 chan. at 2 Ohms Mono
RMS Power Rating: 1000W x 1 chan. at 4 Ohms Mono
Hour Meter
Remote mount digital voltmeter
Remote bass boost control
Heavy duty heat sink
Beveled clear acrylic protective cover
Tiffany-style input and output RCA jacks
Removable covers for control and input areas
High speed switching power supply
Double-sided glass epoxy circuit board
THD: 0.08
S/N Ratio: >100dB
Frequency Response: 15Hz-150Hz
Variable Low Pass Filter: 50Hz-150Hz, 24 dB/oct
Variable Subsonic Filter: Off-20Hz, 24dB/oct
Variable Bass Boost at 45Hz: 0~+18dB
Variable Phase Shift: 0-180 degrees
Input Impedance: 10K ohms
4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
On board hook-up terminals
Dimensions: 18L x 9W x 2H
1-year Sonic Electronix warranty
or throw in a few extra hundreds and get a
Rockford Fosgate Power T2000
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 750 watts x 1 channel
RMS Power (2 ohms) 1500 watts x 1 channel
RMS Power (1 ohm) 2000 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohm
THD at Rated RMS Power Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 pair
Built-in Crossover LP
High-Pass Crossover Frequency
Low-Pass Crossover Frequency 32 - 250 Hz
Subsonic Filter 28Hz
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18dB (Variable frequency: 35 - 70Hz)
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 250A
dont wanna spend the extra money if i dont have to, ive ran RF amps in the past but never Alphasonik so i dont know too much about them. and if you have any other recommendation, let me know..Thank You
FeS RoY
FeS RoY
Down South
FeS RoY
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
