Amp for BTL 12?
FeS RoY
getting a Dual 2 ohm BTL 12, should i get a
Alphasonik 1000DA
1-Channel Class D Monoblock Power Amplifier
RMS Power Rating: 2060W x 1 chan. at 1 Ohm Mono
RMS Power Rating: 1500W x 1 chan. at 2 Ohms Mono
RMS Power Rating: 1000W x 1 chan. at 4 Ohms Mono
Hour Meter
Remote mount digital voltmeter
Remote bass boost control
Heavy duty heat sink
Beveled clear acrylic protective cover
Tiffany-style input and output RCA jacks
Removable covers for control and input areas
High speed switching power supply
Double-sided glass epoxy circuit board
THD: 0.08
S/N Ratio: >100dB
Frequency Response: 15Hz-150Hz
Variable Low Pass Filter: 50Hz-150Hz, 24 dB/oct
Variable Subsonic Filter: Off-20Hz, 24dB/oct
Variable Bass Boost at 45Hz: 0~+18dB
Variable Phase Shift: 0-180 degrees
Input Impedance: 10K ohms
4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
On board hook-up terminals
Dimensions: 18L x 9W x 2H
1-year Sonic Electronix warranty
or throw in a few extra hundreds and get a
Rockford Fosgate Power T2000
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 750 watts x 1 channel
RMS Power (2 ohms) 1500 watts x 1 channel
RMS Power (1 ohm) 2000 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohm
THD at Rated RMS Power Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 pair
Built-in Crossover LP
High-Pass Crossover Frequency
Low-Pass Crossover Frequency 32 - 250 Hz
Subsonic Filter 28Hz
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18dB (Variable frequency: 35 - 70Hz)
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 250A
dont wanna spend the extra money if i dont have to, ive ran RF amps in the past but never Alphasonik so i dont know too much about them. and if you have any other recommendation, let me know..Thank You
FeS RoY
FeS RoY
Down South
FeS RoY
vegang
vegang
