amp for 2 dc level 6 15s?
cocoleveo7686
MA
Right now I have an ampere 5k. The amp will be run at .5 ohms unless I get 2 amps and run at 1 ohm.
But ive looked into:
Audio Legion 8.5k
Crossfire 8k
AB 1100.1
Ampere TFE 9.0
also have looked into Brazilian amps
Banda 7k
Banda 10k
Taramps 8k
and a few others. Basically I want to CLAMP 6000+. So wiring to .5 should give me the best option. My electrical for now is 3 g31, 1 d34 and a 270a alt. I will eventually add a few more g31 or lithium
Don't bother with the taramps 8k's if you want to clamp 6k+ get the hd10k or larger. The 8k might get you a little over 5k although my atomic 5k at .5 didn't even clamp 3k due to rise a crossfire 8k should get you there depending on rise but at .5ohm I'd add another alt. Taramp 10k would make 6k and not need another alt.
subs either need to be wired together at .5 or 2 ohms. or separate 1 ohm and 4 ohm lol.
Taramps I have thought about the hd10000, but heard there are problems with them.
Cant do 2nd alt, I will most likely go lithium
Bass 12k is a beefy version of the 15k. I run two taramps 8k's with 600ah worth of battery and dual 270a alts and voltage is good. You are running half that so the 8k would be fine but I'd go bigger if you want 6k+
There are no problems with the HD10000. It's how they are being used.
The current HD10000 models in the US are not the US modified versions so using them like it is will likely cause it to fail.
The new US HD10000s are about to be here for World Finals very soon so that wont be said any longer once we unload them all.
You'll need more electrical for 6k plus
like 5 g31? I clamped 2700 so far and I don't drop below 13.5
---------- Post added at 02:20 PM ---------- Previous post was at 02:19 PM ----------
I believe the 12k is only 1 ohm not 2 ohm. id have to get 2 ohm if I ran 1 Brazilian amp.
You are sadly mistaken. The bass 12k is the new dedicated subwoofer line of taramps that can handle half ohm(actually there's a vid on facebook where damien taylor did a 0.125 ohm burp on the bass 12k). Brazilian technology has advanced way farther than you could ever think of in the past year. They actually spend time on research and in-house development while the korean amp companies play the re-badge game reusing old designs bringing nothing new to the table.
Whatever you read on the forums about Brazilians is old outdated knowledge. The game changed and will consistently change with the way Brazilians are heading. They arent world champions for nothing.
Batteries and alt
Batteries and alt
I have a 270a alt right now, Know anywhere that sells a dual alt bracket for a 2013 Grand Cherokee 3.6L? If not then 270a is prob the highest ill go. I can do 370 and singer said it will turn on at idle but this is my daily driver
Just installed a Taramps HD8k 2 ohm in and added 40 ft of wire to handle all the current. Stock alt + 240 amp and 3 optima yellow tops and it holds at 13-14 volts on music. Were smelling the coils on his HDS312s for the first time so it must be getting 1200 or so to each sub. Id say 6k out of the HD8k is reasonable unless rise is out of control.
I can ask some of my guys. But I think I may know somebody
cocoleveo7686
cocoleveo7686
MA
cocoleveo7686
