amp for 2 12" rl-p?
chris96camaro
Foreign and Domestic
What amp do most people use to power two 12"soundsplinter rl-p's?
Ok i see that hifonics *****, does anybody know of a moderately priced amp that will put 600-700watts x2@2ohms?
Could i run the kenwood kac-9152(900rms@2ohms) to one of them for a while, then if i decide to get another strap another kenwood to it and run it like that?
check the sig, and if you want to buy an eD within this week a group buy is going on that saves you $50 making the total $300 (incl. s&h).
nine.1
i'd sell you mine, but this **** group buy is a better deal than I can give you //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Is the jbl 1201.1 a good choice? 1114 watts RMS x 1 @ 2 ohms 14.4V
Does jbl make good amps?
How about the MTX 1501D, 1000 rmsx1@2ohms, are MTX amps usually good about coming cloe to their rated power?
ur getting 1200 at 1 ohm at 12.5 Volts from eD..........right now watt per dollar with build quality in the mix eD has the best amp in t hat range, matter of fact, ordered mine yesterday
How much is that @2ohms, because the subs can only be wired down to 2??
i dont think hifonics *****. however there are better amps. i dont have my rlpd4's yet but i do have a bx1500 and if it isnt good enough ill switch. but 200 bucks they are good for the buck i think. i have not tuned my 6400 yet but it sounds good as is.
u got dual 2?????????????? wtf? anyways.....900-1000 at two ohm
The subs are 12"rl-p, dual 4ohm , so they can only be wired down to 2 ohms...
And do you guys think one will be enough, i mean i dont know how loud these things get?
wrong.....u wire EACH to 2ohms.......run them together at 1 ohm. ur final load will be one ohm.
152
385
  • Locked
690
Amp
499
chris96camaro
chris96camaro
Charlotte, NC
denim
maylar
    Jun 2, 2024
    Jun 1, 2024
