amp fans
jellyfish420
i design boxes .......
i was thinking of putting a fan or 2 on my amp, do i a) put the fans beside my amp to blow across the heat sink or b) take the top off and blow them directly in the inside of the amp on the circuits and the such. here is a pic of my amp, its under the driver seat. . . its harder to steal under there.
showphoto.php
I don't know if I would take the top off and blow air right on it because if anyone was in the back seat, one small move of a foot and your amp could be screwed. I have my amp mounted in my trunk and here is how I have my fan:
Correct me if I'm wrong, but I think the only part of the amp that gets most of the heat is where the resistors are (as you can tell where my fan is located on my amp). I would cut a whole in the top for the fan to blow directly on the hottest part, and on the opposite end of the amp, cut a whole for the air to circulate.
Well, on my amp, the only part that gets hot is the big resistors you can see underneith the fan. The other side of the amp doesn't get hot. I don't know much about how reansistors work. I do know for a fact that resistors get hot (because I've even touched it) so I know that's one reason my amp's heatsink gets hot.
the transistors are bolted to theheat sink to dissapate the heat. look at the top side of your amp. . . see them. ya the resistors get hot but they are made to, the transistors are the things that you haveto worry about keeing cool.
Well' I've touched the transistors and they are no where near as hot as the resistors. Anyway, try like I said if you want. Put the fan in one side of the amp and a port on the other end to completely circulate the air. Backpreasure is kinda key here. 2 fans on the ends and a single whole in the middle would work as well because the air going into the amo would be forced out causing the circulation to be greater ina since. Plus, the amp isn't completely sealed off on the edges so that will help as well.
the transistors don't get as hot because they're bolted to the heat sink to dissapate heat. have you ever touched the sides of your amp? alot of that heat is radiated out from the transistors that are bolted to it. transistor have to stay cool beccause they arewhat amplifies the signal,if they get hot they become less effective, the you get a distorted signal.
double post.//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
jellyfish420
jellyfish420
STL ill side
tristanlee85
