amp cutting out only while driving
onesexyga
NH
ive had my amp for 2 years. Never cut out once. It's a sony 2200gtx. I was running 2 4 ohm subs in parallel. I just put new subs in that are 4 ohm dvc. They are bridged to 4 ohms. I used the correct terminals on the amp for bridging. The subs hit great while the car is on acc or idling. As soon as i start driving, the amp cuts out. I set the gain by the gain setting tutorial. Any ideas why it only cuts out while driving?
please, i dont need to get ragged about the brand. Its what i could afford. It ran fine for 2 years. I have a problem and im looking for some serious help.
All the connections look good. Obviously the first thing i checked. Thing is when its working it sounds as good as it ever did.
Okay, but my amp isnt cutting out because of heat. It has something to do with driving. When i installed my subs i tested them in my driveway for a while. The system heated up but it never cut out. I can run it all i want in park. It dies within seconds while driving.
does it go into protection? it should have a display light that will give u an idea of whats going on. it cant be pulling enough current to shut off.....gl
onesexyga
onesexyga
NH
luvinthebass
