Amp cuts out
slapperz
So here's my deal i have 2 kicker cvr 12's DVC4 wired to 4 ohms on a kicker 600.1 that does slightly under 300 rms at 4 ohms. Also just 2 days ago bought a new batt optima yellow top D34.
Now when i play songs the amp and bass cuts out some songs i can turn up high to 75% but others cant even get to 50% without cutting in and out especially songs with really low notes. Now i noticed my door and high beams dim at the same time when those bass notes cut out but i just bought a new batt. because i thot that would solve it?
Also this only happens when i have both RCA's in the input. When i only have one RCA in(left side) it can go higher but doesnt hit as hard.
I tried re grouding, new batt and hooked up amp to a set of alpines and same thing but i dont get how 300wrms is too much for my electrical??? i used to run 600wrms fine on two hfi's before they blew on a stock batt?
well your using the wrong amp for one. youre only sending those subs 150 a peice...plus ur cranking it and clipping the crap out of it im sure. buy new subs or a new amp
Well the gain is set at slightly under the halfway point(i know that doesnt mean half way up or half its rating) does clipping induce amp cutting out? I thought it just creates heat on subs and possibly blows them? Cuz when low bass notes hit at like 15/40 of volume it cuts would that be clipping? i nvr crank up past 75% of my max tho
slapperz
slapperz
The Bay Area
GlassEyez
BP1Fanatic
BP1Fanatic
