Amp Crossover Help
poorblackman
I will be getting some 4 inch Polk dxi400 speakers put in soon along with the Alpine MRP F300. I was curious to know what should I set the High Pass Filter to? I was told that it wouldn't be a good idea to try and get any bass out of the speakers and that I should set the HPF to about 400hz. Is this correct, or are there any other suggestions out there? Thanks!
i have the mrp f300 i have JBL GTO608c Components in front and a sub bridged, if u have a sub, i would set the polks to HPF and then set the rears to LPF and i use bass boost b/c i only have a 10" sub.
Depends. What speakers are in your car altogether.
At high volume levels I wouldn't run them under 400. 300 probably the lowest depending on Howe your going to dive them.
I am putting the Polk dxi400 speakers in all 4 of my doors on my 1996 Toyota Avalon. I am also getting a mono amp and a 10 inch sub put in, so I'm really just trying to get some ideas on a crossover set up for my system.
poorblackman
poorblackman
Norfolk,VA
calebkhill
