Amp cooling
jguti92
:mad:ok well i will give you a run down i had to do the big three upgrade because of voltage drops and amp over heating...... well i did.... i put 2 gauge wire for my big 3 and i am running a 8 gauge power wire to the amp( upgrading wehn i get money) and a 2 gauge ground from the amp, it fixed my voltage problem lower it goes is 12.3....... the heating problem is still there!//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif i have the speakers wired up right... so i am thinking of putting pc fans on the fins of the amp so my qurestion is where exactly do i postion the fans? should they be brigging air into the fins (blowing in) or blowing air out of the fins( blowing out) ? open to any other suggestions let me know thank you!!!!!!!
SYSTEM SPECS
CRUNCH P1100.2
kicker cvr's 4 ohms x2
boss 2.0 farad capacitor
where your amp is mounted is important for cooling. maybe a pic of it would help. the best way to do this would be to make an amp rack. your amp will go inside the rack and you put a fan on either side, push or pull it doesnt really matter. the best way would be 2 fans, one on each side, working as a push, pull. inside the amp rack all the air that moved through the fan will go across the amp fins. doing it any other way is just kind of... janky. i have 2 amp racks in my car and my amps dont even get hot anymore. i think i have a link in my sig if you want to look at what im talking about. bcae1.com has some good info on amp racks.
jguti92
jguti92
FLORIDA
jguti92
