amp cooling box
I don't mean to sound like I'm insulting you but you know that you can get amps with fans already in them, right....A high dollor audiobahn I saw earlier had two on the top....There really is no reason you should need a box made just to keep you amp cool....What kind of amp is it?
Adam
I know you can buy self-cooling amps. but I already bought a phoenix gold xs2500 a couple years ago. and I have no reason to replace it. the box is more for security purposes. i own a standard '92 rodeo that doesnt have power locks or anything special. it is very easy car to break into. my original idea was to make kind of a cover-type box where I can bolt the amp down in my trunk, then bolt down the cover over the top of it. kind of a double wammy if someone is going to try and jack it. i just need something to cool down the amp when its covered up. i just wanted to know how the fans work and if it would be possible to build something like this.
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
6
225
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
323
4lowrodeo
4lowrodeo
American Fork, UT
natem33
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
