amp/comp question
jco1385
expert jcologist
i'm getting a set of components, and i've never wired any before. i am gonna tell you my idea, and you tell me if i am wrong, or if there's a better way. here goes:
i have this amp: (PS4-800)
http://www.dealtime.com/xPF-Power-Acoustik-POWER-ACOUSTIK-POWPS4800-4-CHANNEL-800-WATT-AMPLIFIER
and this is the comps im getting: [Polk MM6 (minus these tweeters)]
http://www.polkaudio.com/caraudio/specs/mm6/
with these tweets: (Polk MM400)
http://www.polkaudio.com/caraudio/specs/mm400/
since they are 150wrms @4ohm, i'm thinking bridge the amp to 2ch @~160wrms per @4ohm and set gains conservatively. will this work? will these tweets be ok on those crossovers? sorry for the n00b questions, just wanna get it right the first time. also, i'll run the rear 6x8's for fill off HU power.
will the crossover cut the power to the tweets to 25wrms (what they're rated for)?
what do you think?
jco1385
expert jcologist
jco1385
Mobile, AL
jblayz1
