Depends on sub. Was it meant to be in a large or small box?if i make the box larger will the rise number be smaller like 2-3 ohm or would it get larger?
Slot port/aero/octo?a sub like the tantric hdd 15. would it be better putting them in a huge enclosure (9cuft per sub) or the company recommended enclosure size.
If its a wall the whole box if done correctly should be open in the inside with 2 ports so box rise wont be much compared to a smaller single sub box with more pressure inside.wall with 2 12x8 ports per enclosure.
I highly doubt you will need that much space unless your doing 5+ subs.if i am using two amps, one for each sub you still recommend using one large enclosure for the subs. i can get about 18.5-19.5cuft but need to make two different enclosures. so just one port rather than the two? if i am using for daily and spl you think i should use aero ports instead?
Lord so help me if this is true. I will rip those puppies out right now and rewire it. If possible.Anybody correct me, but cant a .7 be wired parallel to get .35 or so, then with box rise will be near 1 ohm.
