Amp capability (OHMS)
JerryLZ
If I go with a PPI P1000.1, Which subs should I buy that will be compatible as far as 2D/4D? I can't honestly say I understand the difference between the two..yet
NOTE: Ill be running 2x 12's if that matters. 2x Sundown EV2-12's which are available in both dual 2 ohm or dual 4 ohm.
Amp specs are listed below:
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
2-Ohm Stereo, 4-Ohm Bridged Multi-Channel
1-Ohm Stable Class D Monoblock
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable (2/4/5 ch. models)
Variable 12dB High, Low, & Subsonic Crossovers
Band-Pass Crossovers (4ch & 5ch.)
Input Source Selector (4ch. & 5ch.)
Variable 12dB 50Hz Bass Boost (1ch.)
Dash Mounted Remote Gain Control (5ch. & 1 ch.)
Direct Wire 8ga. Power & Speaker Terminals
0ga Reducer Terminal Included
JerryLZ
JerryLZ
Cleveland, Oh
JerryLZ
