Amp bridging.
Is it normal for an amp to be already bridged, without putting a bridge wire to connect the 2 channels? My Clarion APX2120 seems to be already bridged internally somehow.
Please tell me you have never directly connected two terminals with a piece of wire.
Most of the time there is a switch/button to bridge the amp internally. A 2ch amp isn't magically bridged without you telling it to bridge.
If by "tested one pair of terminals" you mean you tested one individual channel, and by "tested both pairs" you mean you measured the terminals used for bridged operation.....then measuring double the voltage [bridged] compared to a single channel is exactly what should have happened.
Yeah, I know but I never did anything to bridge the amp, it has a mind of its own.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
All you need to do to "bridge the amp" is to utilize the two terminals specified to be used for bridged operation.
That's it. Nothing else. If you connected the red DMM lead to the positive amplifier terminal to be used for bridging, and the black DMM lead to the negative terminal to be used for bridging....then that's it. Nothing else needs to be done. You measured the bridged voltage. If you were to connect speaker wire to a subwoofer at those terminals instead of DMM leads to a DMM, then you would have "bridged" the amplifier to the subwoofer.
So amps that have a switch or button for bridging, what does that do internally?
My RF200.2 had a switch for bridged or 2ch.
Without being familiar with the amp and not atleast looking through the manual/etc, my guess would be that it's not so much as a "bridged/unbridged" switch as it is a stereo/mono switch.
brendan_121212
Saudi Arabia
brendan_121212
