amp blown?
robert420
i have a lanzar vbr 124 in a custom ported box with the built in amp. i used it for a few months, then took it out because i sold the car it was in. i tried installing it again and all i get is a loud popping/pinging sound out of the subwoofer. im assuming the amp is somehow blown? no fuses are blown, all the wiring is correct..
What amp?
doesn't matter if wiring is correct, you need to see if there is resistance at the grounds you make for the amp to see whether if your ground location is a good one or not because its different for each car, surfaces need to be sanded down to bare metal too. Take out a multi-meter and check resistance at each area.
robert420
robert420
geneva ne
robert420
