Amp Blown, Faulty Wiring, need some help!!!
Hook Me Up
It's Bad Boy Baby
I just installed some 0 gauge wiring and i accidentally hit the power on the ground wire and it made a huge spark. Now at this point it was not hooked up to the amp. When i hooked the power to the amp, it made another spark, very tiny though and the guy at the electronic store said it was normal for that little spark.
Well now my sub, doesnt work and i wanna know if u know what fuses might of blown. I check the main fuse in the wiring, and the 2 on the amp, but there fine ne others that may make this thing work
You should always disconnect the negative battery terminal before doing ANYTHING electrical...
But open up your amp and check for any brown/black marks on the board. If anything is even slightly blackened, it needs replacing...
And check your remote lead...
Any insulated wire that passes through metal - like a firewall - has the potential to rub and slice the insulation due to vibration and time. It has happened before, and when it does the battery tries to discharge into a dead short. A couple of hundred amps almost instantly. Needless to say, your power wire doesn't like that too much, and will catch fire due to the heat...
The fuse near the battery stops this from happening.
Hook Me Up
It's Bad Boy Baby
Hook Me Up
Indiana
JimJ
