Amp and sub decision
  • 4
devast8r3436
Ok guys I think I've found my setup. Cadence ZRS12-1000 hooked to a Autotek M4000.1D. 1000 watts plus my ZRS C9 so I'm going to do the big 3. My alt. is only 100 amps so I figure maybe upgrade it to a 150 amp one? And get a Kinetik KHC1400 for a second battery. Sound like a good setup?
Should be nice. As long as you build a nice box or have one built. I'd get a dual 4 and run it at 2 on the MM. Otherwise you;d be overpowering it running at 1 ohm.
Most of the ones on the classifieds I don't know which are good or not. I'm looking for a amp that does 600watts rms at 4ohm and 1000watts at 2 ohms. Any decent ones in my range? The MB does 550watts at 4ohm. Am I gonna tell much differece with 50 watts less? And does that Audiopipe do rated? I'm assuming it's more SPL over SQ?
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
501
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
495
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Yes on both of these. Splicing means connecting one wire to another. So one wire to the positive and one to the negative wires or terminals of...
861
devast8r3436
devast8r3436
Heber Springs, AR
devast8r3436
    Apr 27, 2024
audiobaun
    Apr 27, 2024
